I have a Cyberdyne digital dash, Brand new, never used, in the cyberdyne box.
Includes all the sensors, also new in their boxes. This is the 3 Bar sensor version of the dash.
All the instructions to install are still in the box.
This dash has system volts, water temp, oil pressure, tach (both digits and bar graph), 3 bar MAP boost (ie, Max of ~28 psi reading), speedo.
Has an interesting 0-60 feature where it will display your measured 0-60 times. You can also set the bar graph so your redline is at your desired redline.
If you're wondering what this looks like, this guy has one installed (starts at about the 1:00 min mark):
Asking $300. Would also consider a trade for a complete HR parts rear sway bar setup or a Spohn rear sway bar.
