2.5 dp or 3 inch
85 ttypewh1
fire fighter
I want to run around 11.5-11.7 would a 2.5 be enough or do i need a 3 inch. Also will the factory pass header work into the 11s. I have been reading alot of these sigs and see people with alot of mods not running as fast a some people with less mods. I will not ever want to run faster than 11s because this car is my daily driver and i dont want to spend the thousands of dollars just to go a second quicker i have tooo many other toys to put money into. Please read my specs and let me know if i need to upgrade or down grade or add anything. Thank you.
current mods:
340 fp w/hotwire
adj fpr
14" k&n
tb coolant line bypass
dual rear air bags
hooker 2.5 cat back w/test pipe
grainger boost valve
valve cover breather
front mount ic
Future mods:
44-49 turbo
42.5-60lb inj.
2.5-3 inch dp
alky
some kind of maf
87 ecm upgrade with coil and mod
some kind of 93 oct chip
good tires
box lower arms
and anything else you guys think i need without overkill
