2 alky questions
OneLethal87GN
R.I.P. Lethal GN
First question.. Would it be better to run higher timing and low boost or vice versa? I would think the lower temps from lower boost would be better than lower timing. Any comments?
Second question.. Would it be OK to hook a Kenne Bell Boost-A-Pump up to the alky pump? I was thinking it could allow you to run more boost due to both better atomization from the higher pressure and the increased flow. Has anyone tried this either with a B-A-P or hot wire kit or something?
I like the idea of higher timing....then if you have a malfunction with the kit, you won't be as liable to blow your headgaskets as you would with higher boost. That's a theory though, I don't know for sure.
I would definitely not use a boost a pump. The SMC kit has all the adjustment you need for increased flow. I think he's working on a two stage kit...but I could be wrong.
Still got the Syclone and the TTA? :)
Not true, high timing will cause extreme cylinder pressures just like turbo boost will.
You want to get into the "sweet spot" of whatever turbo you are running. For a TE-60 that is going to be around 24-25psi. So start with low timing, get your car set where is runs 24psi or so, then add timing until the knock sensor feels a little tickle. It may take a couple of different chips or a spark translator to find the right timing.
I plan on getting a custom chip burned for my combo later on. For right now though I run the high timing ( @ 30 degrees ) chip because I have cheap clamps that don't hold alot of boost, and it has l/u which my street chip doesn't have. I have the l/u switch but I'll probably forget to hit it if a race suddenly came up. Even with the high timing I can run @18 psi with very little to no knock.
It's true that higher timing works the best with alchy. Also true that if you lose spray at 30* you will be shopping for head gaskets.
I'd say keep boost to 22-24 psi, no more than 25* timing.
JMO
you can definately use higher timing, needed, in fact, to leverage turbo spool-up due to the w-a offset.
25 degrees is, imo, actually kinda low, at least relative to what me and Dman usually run.
As far as blowing head gaskets, let me tell you, the *stock* factory head gasket/torquing result is beyond reproach.
Just one (of many) example:
yesterday, while showing off for a BMW, I suffered a w-a system, uh, 'malfunction'.
I was 4th gear, WOT, 27lbs boost. A look at the DS data showed 25 knock counts (yikes, higest ever! ever!), 8 to 12 degrees continuous retard, and 1810 (!!!) def F. EGT.
You would think I did some amount of incremental damage, and I probably did, yet, after fixing the w-a system, another run at 29lbs and 1690 EGT proved the car running as usual.
Bottom line is, these factory turbo blocks are friggin tough, man.
>>you forgot to turn it on, or forgot to hook up the nozzles>>
nahhh...that would infer I have a brain, even a small one ;-)
It was my own slip-shod craftsmanship that let me down.
Ian, the "sweet-spot" for a TE44 is 26psi. Like he said, high timing will kill your headgasket just as quick as high boost. I am a low timing/high boost kind of guy. There is more hp per psi when you raise the boost than when you up the timing. A benefit of higher timing though is that you won't burn as much fuel as you would if you had upped the boost.
-DC
