just plain john
El Camino a Go-Go!
- Feb 24, 2007
What's the difference? Why would someone change from 2 to 3 bar?
SignUp Now!One bar is about 14.7 psi or one atmosphere. A two bar sensor will read 29.4 psi. If you are running high boost the sensor is not that accurate at the higher boost levels and you should go to a 3 bar sensor.
absolutely none ... unless you consider the weight loss of 85$ from your walletOne more thought....so if I'm not running a xfi or similar system, and I don't run an alky kit, then there's no benefit?
It will throw off the dash boost gage.will a 3bar map work on a mostly stock car or will it mess up the analog in dash boost gauge ...
