87TTypeKid
- Jan 23, 2006
In the process of re-doing my front end, I'm realizing that 20 year old nuts and bolts seldom enjoy being removed, as per the resolved argument between my dremel and upper shock mount bolt. The destruction of 1 c-clamp also leads me to believe that the front retaining bolt on the lower control arm is seized to hell.
I have new suspension pieces arriving tomorrow, but they are no good to me if I cant get the old ones out. Any recommendations on the following procedures-
1) upper control arm removal (tips for tapping out the splined mount bolts when there's no room to hit them with anything)
2) lower control arm bolt removal if the bolts are seized into the inner sleeve of the bushing and can't be hit out with a sledgehammer nor pressed out with a fabricated tool consisting of a c-clamp and a piece of an aluminum pipe (and penetrating lube seems not to work)
3) removal of old bushings from control arms
4) removal of lower ball joint from control arm
I'd preferrably like to stay away from methods involving a torch, considering that there's an as-of-yet-unlocated gasoline smell (most likely a dead vapor line) and I want to live slightly longer than the 23 years that I have already lived.
Also, my car is on jackstands to do this, so my mobility is limited...extremely...and the gravel driveway hurts to roll around on..haha.
Thanks for the help for all who can provide info from experience. I just want my suspension back up to snuff so I can get back to pissing off my import friends by having a larger car that can still handle just as well as they can (Incase anyone's curious- as far as the publications that I have read can tell me, a T-type in good shape can pull the same .80 g's that a WRX can, which, before my whole front end one day took a dump randomly, I can agree with).
