2004R Direct clutch backing plate needed
PaulRV6
Are these still available from GM? I believe the P/N is (4.50mm)) GM #8632570. If not where else can I get one?
I also need the thick beveled snap ring for center support to case.
paul
Check with a trans vendor or pm ineedagn and see if he wants to sell anything.
Are you referring to the Direct Pressure Plate, if so I stock them. I also have he snap ring you need
No not the pressure plate but the backing plate (it measures .177" thick and it is slightly beveled). I believe I found one from a vendor. Thanks
paul
The direct pressure plate measures .177
Ok, that is the part I am referring to. Maybe it is just terminology but the ASTG manual calls it a backing plate fig. 7A6-122. So they are one on the same?
Thanks for the clarification if thats the case.
paul
Dave, could you confirm that they are one in the same? Thanks
prc
I will confirm they are the same part, if you were to order, you would look under the clutch pressure plate section of the parts catalog.
