2004r first rebuild
mommasGN
Hey guys. My 180,000 mile transmission is still shifting great. Only thing done to it is a shift kit. However, The front pump is leaking around the o-ring and last time I had the pan off there was some clutch material in the bottom. I figure I'll go ahead and give it a refresh. Couple questions.
I'll probably never go bigger than stock turbo so I don't need anything ectreme. Do I need to upgrade anything? Do I need to replace, or re-build the pump? Should I replace the converter and if so what stall? If anyone can think of anything else I'm missing please let me know.
Thanks so much.
Thanks so much.
If the trans works well and all the parts are in excellent condition, you can just do a stock style rebuild. I would do a few upgrades though depending on shift kit installed. Contact me and I will answer any questions you may have. I can set you up with all the correct parts for the rebuild.
