I've joined your forums in hope that you guys can provide an education to an old school Pontiac guy. I have a 1974 Trans Am (Yes, it's a Super Duty for those who know about such things) that is modified because I want it that way.
I want an OD transmission for it. The car has a 462ci motor with no power adder. It's making a bit over 450 HP and over 500 ft. lb. of torque. For those who don't know traditional Pontiacs, they are a big bore, long stroke motor. This means massive torque hits on the transmission when you launch at the drag strip.
My real concern is that huge torque hit off the line on good tires. Will it take the shock of a heavy car and tons of torque on a launch. Us old school, heavy iron guys keep hearing the horror stories of the 200r4 taking a dive after 3 passes in our cars.
I know you guys make more horsepower but is that translating to big torque on the bottom end? I simply want to find a transmission that will bolt up with a minimum of fuss (200r4 has the BOP bolt pattern) but will take a beating from a big torque motor.
I spoke to a Bowler transmission rep while on Hot Rod Power Tour. He was quoting over $4K for one. Should I expect to pay that much for a solid, 200r4 with a good converter?
