200r4 lock up wire
mr g
hi i just bought a 200r4 trans for my 1981 el camino im swaping out the 3.8 to a 350 and the turbo 350 to a 200r4 but theres is something i just notice that on the wire that hooks up to the trans the one that comes from the car is two wire and the connection thats on tranny is for a tree wire hook up. is there a problem that i cant used this tranny or is there a way to macke it work i hope there is. please help thank you.
:frown:
What trans was in the el?What is the code on the rear dogtag of the trans you want to install?
im not shure im at work right know but ill check when i get home.
it had a turbo 350. the # on the tag that im going to installed is 2981t830g0332
The plug is different as well as the ecm strategy for converter clutch operation.You will need to make some small changes to the wiring to make lock up effective,
