scot w.
GNSperformance.com
- Feb 19, 2005
Well since I bought my new "T" my goal was to be able to run 20lbs of boost with only 93 octane and have NO Knock!
Although I'm a Firm believer in Razors ALKY kit and will more than likely end up on this car, I first wanted to see what I can get out of this car on just 93 octane alone.
The car had a stretched stock location I/C on it when I bought it and it was set on 17lbs of boost and did not get any knock while test driving the car. well after I got the car home and disconnected the battery to do some work, it lost the settings in the chip and I never got over 15lbs of boost without knock. Well the settings in the chip must of been masking several issues. The old fuel pump was heating up after driving and loosing fuel pressure,( I replaced the fuel pump with a Red's XP ) and then my fuel press went wacky. It showed 70psi at idle and the press went Down as I gave it gas, ( I then replaced the Return line with 60psi gas line) and that fixed that.
I also wanted to have a new fuel regulator but just couldn't see spending the extra cash for a new one so I called ACCUFAB and I sent in my regulator and they rebuilt it and tested it for only $25.00 Now everything is up to par and ready for tunning...
Well today was the first time out with new fuel pump, rebuilt accufab reg, and front mount. WA LA!
1st pass, 19lbs / No knock!
2nd pass, Turned up the boost 1lb got 20lbs boost and No Knock!
I thought it was going to be harder than this to achieve 20lbs boost on only 93octane!! The next step is to see just how much we can get on only 93 octane....
Now there is traction issues !!! A good issue to have... :biggrin:
More testing to do in BG!!!!
