218/218 or similar flat tappet cam
jdpolzin
Playing around with an NA build. I'm looking for a used set up that somebody has pulled out and kept the lifters in order. This is a cheap cheap throw together project so not wanting to spend a bunch of money but if someone has this set up and can help me out, I'd appreciate it!
are you looking for roller or flat tappet? I have a Comp Cams 216-220 hyd. roller with lifters and approx. 1,500 miles. If that's something you might be interested in, DM me.
I have a Comp Cams flat tappet 212/212 with the lifters in order. It has only break in time on it. My 3+ year wait on the Comp roller came in a few days later. $120 + the ride from Avondale,AZ. 85392
623-877-8553 I'm not on here much.
TIMINATOR
TIMINATOR
Thank you. Looking for something a bit larger to help get this NA motor to breath.
