The_Darkrealms
- May 9, 2003
Ok I've got a Toyota 1984 ExCab 4X4 that I'm putting a Buick 231 3.8L V6 in (and no its not a turbo, at the time of purchase I didn't even know buick made turbos). I'm kinda new to engine work. I origionaly got sold on the buicks with a skylark I owned, it was a 4 banger but it still had a lot of power for its weight so I figured I'd go with the V6 for my truck.
*I was wondering whats a good tourque and gas mileage cam. I don't really care about horsepower. I'm looking at the high end of the power curve somewhere around 4500rpms.
*Its been recomended I get an aluminum intake manifold and get rid of the two barrel carb and get a four barrel. The engines a 83 or 84. I'm also replacing the smog pistons (partially because I had to boar the block a little bit).
*I'm gonna be setting it up with two inch exhaust, not sure about the intake at this point, might just set it on the carb.
*I'm also not sure what kind of fuel pump I'll be needing for it, I'm sure the stock toyota one won't do the trick : )
