275/60/15 clearence problems? Spacers?
87GN_ponykillr
Buick addict
Hey guys I just got a set of 275/60's tonight for outback for a great $$. Thanks to my buddy Doug (1of1547) who also uses them, He has spacers but think I *may* be able to go with out spacers. My car is just a stock suspension car now, All I plan on adding is air bags and spacers if need be. So Spacers, Yes or No??
WIth T-type wheels... no spacers. With GN wheels, its hit or miss. It will definately rub the frame in some situations (maybe only in extreme cornering) and it will definately rub LESS with spacers if you find the rubbing too much for your comfort level.
Nitto's are narrower than BFG's so they will rub less.
a 1/4" or 5/16" spacer should be enough. Make sure you torque the lug nuts to the proper setting. If a couple are loose, you can shear them all off when using a spacer.
