2nd alky nozzle
SIXBANGR
mean old man
At what point is a 2nd nozzle needed? I can't get rid of the knock no matter where I have any of the settings. 63E, ported irons, cam,FAST, PTE stock location.thanks. Razors kit.
... When you want it to look cooler... :cool:
What nozzle size and appx power is your setup?
Phil
Lauren,
Julio recommends two nozzle if your in the tens. I installed the dual nozzle system from the start. I absolutely love it.... especially since my nine second ride is now my daily driver until I can find a beater.
Send me one of your .logs and let me look at how things are going with the tune-up.
Timing plays a role, air fuel ratio, compression, etc.. How greedy your getting with your boost.. etc.
Make sure your crank ref timing is setup correctly, in other words get a timing light and confirm your timing. talk with your tuner on this.
Typically TR's that can trap over 124-126 I will suggest going to a twin setup. If you need advise on setting up the controller.. call me. Dont guess on these issues. You'll get into trouble quick.
