I just did a mod on my 2nd cooling fan just like I did on my '89 GTA. I have the primary fan set to come on at key on by running a tap in to the ground of the green/white wire off the relay. For the second fan I did the same thing with a pull apart connection tapped in to the green/yellow wire off the relay. The second fan does as I want it, comes on at key on but does not go off when I turn off the engine, hot or cold. I know it will run for so long on its own when the engine is hot but will run indefinitely unless I pull the connection apart and reconnect it. Can anyone tell me why I have to reset this? Does it have to do with the circuitry for the 2nd fan running till the engine cools off? Any info is greatly appreciated.
