turbojkt
- Feb 1, 2003
I'm wondering if there is any problem using a rim with 3 1/2 inch backspacing?
I figure I can fit 325/50/15 ET Street RADIALS on a rim with 3.5 or 3.75 backspacing. (with air bags and rolled fender well lip)
Any ideas or suggestions?
Here is what I have now....
26 X 11.50 ET Streets.
Sidewall width is 12.0 inches.
The rims have 4 inch backspacing.
There is a good half inch between the frame and
the inside of the tire. (Probably 5/8's of an inch)
325/50/15 Street Radials have a sidewall width of 13 inches, so on my
rim with 4 inch backspacing there would be about 1/8th
of an inch between the inside of the tire and the frame. They
are approx 28 inches tall.
Is there any reason I shouldn't use a rim with 3.5 inch
backspacing, or one with 4 inch backspacing and a
1/4 inch spacer? A rim with 3.5 inch backspacing should
handle a 325/50/15 without rubbing on the frame.
87 Limited....TE62, RJC boost controller & power plate, 50lb injectors, Turbo Tweak chip, 9 1/2 multi disk converter, TH downpipe, 3 inch single shot, SMC alcohol inj.
