Frame Notch PIA, What Are Your Labor Details, Price and Money??
Finished, 325/50/15 tuck in there now.
30" wide in case I ever run that tire.
Had to remove the spare tire panel so they could get access to welding the inner 1/4" brace for more rear frame support.
Did you do anything to the tubs.
Post 18
They did a cut in the tub area the tire would rub on when compressed, then pushed the panels in and filled the gap to make it look like the factory well panel. It was my choice to do this vs a real mini tub panel since I didn't want to do that and make it look even more modified. I tried to keep this factory looking which in the end was a major expense vs a Schwartz frame and mini tubs.
I am not sure is this panel mod is necessary vs other frame notches that just pound it back. Since my frame went in a little deeper than normal (I'm past the seem) and we added the 1/4" plate that went inside frame then through the rear bend area frame etc the more tucked BS created a bit more rubbing areas. I needed a similar cut and blend to the well area right above the middle of the tire since it came in so far.
I'll say this, it's about as factory looking frame notch as you're gonna get, it was way more $ than expected, it tucks nicely and it's what I wanted. If this mod and 325s don't hook I'll be pissed.
Post 18
The reason i ask is cause i did the same thing. I also shorten my rear 1 inch and the lower control arm mount. and i want to put a 325 tire also
My Moser was at least 1" shortened, running 15x10 with 4.5" bs the 325 just fits with maybe 1/4" space from center tub above the frame. But my notch is deeper than normal and I'm not positive how much the axle housing was really shortened.
