Ill give ya an example on fit. TSM racer Keith Egan ran several turbos this year. Both times the 3.5 in DP fit differently. Not because of the down pipe but the turbo flange differences. Hes had to cut the pipe and reweld. I had to clearance mine around the frame area. i never ran an AC box with it.
In other words , its a quality piece and it fits very well for how large it is. But lots of things will go into the fit of it in any one specific car. Motor mounts, body bushings, turbo mounting flange thickness..yad yada..
These problems occur with a 3 in DP but are not as amplified as with the larger. Now you ad the large collector area and crossover used with ATR headers, things get even tighter.
At this point you are better of building your own. I built a 3.5 out of mild steel as a template for a stainless unit i will some day build. So far the home made DP has done rather well so i dont wanna mess with it.
