I would say nobody would dare to post some hard data to support strength between the two. Heck, we couldn't get hard facts on a 2.100 rod journal crank strength other than speculation. The 3.59" stroke will be more suitable for 6.5" rods for piston design issues. I do not know what the 6.5" rod in the above equation means, the piston still travels the same distance either way given different rod lengths with the same stroke, the pin on the piston would be in a diffent location. Dwell time comes into play, but Ruggles stated no dyno differences have been noted on his engines. I would go with the bigger stroke if I could choose either crank for the same $$ unless I would compromise piston strength because I had long rods already.
