GNcollectables
- Dec 12, 2005
Here's some engine goodies & supporting items:
** aluminum vacuum block, 6 port, used but nice, some scratches, $15 shipped.
** heat wrap material (its reflective sheet coated bubble wrap; roll: 16" x 18') new, $30 shipped.
** caspers, crank sensor kit (sensor & bracket) $50 shipped. {I have 2}.
** Magnecor spark plug wires, new, R-100 Racing 10mm pure silicone, red. $75 shipped.
** Magnecor spark plug wires, slightly used (red finish is dull), R-100 Racing 10mm pure silicone, red. $55 shipped.
{ the top wire set shown in pics is the new set }
** 9" pusher electric fan, formula brand, new in box, perfect for trans cooler, etc. $60 shipped.
** Bosch adjustable fuel pressure regulator # 0 280 160 233, 4 port, $35 shipped.
** solid Roller Lifters set, comp cams, used but nice, $210 shipped.
** Walbro 834GMHP in tank fuel pump, new in box with install kit, $105 shipped.
(as seen here {replace the 3 X's with dotcom}: fullthrottlespeed.XXX/customkititems.asp+kc+834GMHP+eq+ )
** walbro F20000169 (same pump as the GSS340M; high pressure 255 ltr/hr; listed as a stock replacement pump), used but nice, PUMP ONLY, $55 shipped.
** comp cams Hydraulic Roller cam # 269HR, 112 lobe center, RPM RANGE: 1500 to 6200,
DURATION: INT 269 EXH 264, DURATION AT .050: INT 218 EXH 212
VALVE LIFT: INT .511 EXH .504,
see more specs listed at Comp Cams site: (compcamsDOTcom then search grind #269HR) OR at SUMMIT ($289): (replace 3 x's with dotcom): summitracing.XXX/parts/CCA-69-400-8/
This is a new in bag cam, but I do not have the box (or cam card) for it! $185 shipped and its yours!
"shipped" means lower 48 in U.S.!
Looking for factory parts?:
http://www.turbobuick.com/forums/parts-sale/332073-1987-factory-gn-parts.html
How about some Grand National Diecast cars?:
http://www.turbobuick.com/forums/bu...30202-rare-buick-gn-gnx-tr-diecasts-sale.html
