Thread will be updated as items are added/sold. Combine products for a discount.
SD2 chip w/instructions. Default setup is as follows and pretty much everything besides idle speed can be changed in PL: Gasoline; 60lb injectors; 6262 turbo; FM intercooler, N/L 3200 converter; 218/212 cam; normal ported iron heads. $200 shipped
UMI Performance coilover bracket kit (p/n 3049) which retails for $340. The brackets themselves are used but I pieced together a kit with all new hardware after deciding to go with the lower control arm relocation brackets instead. $250 shipped
Billet vacuum block. Tapped for vacuum brakes. Plug installed or purchase a 3/8" barb connector from Amazon or any hardware store for vacuum brakes. Also countersunk the bolt head areas and added slightly longer stainless bolts for a more secure connection to the throttle body. Red loctite on ports. Gasket included. $40 shipped
Comp Cams 5334 valve spring seal installer. Used for installing PTFE .530/.531 seals. $30 shipped
Three pairs of old school standard Fel-Pro cork valve cover gaskets. Free set to whoever purchases something if they want them...or $30 shipped for all three sets.
"Real" Art Carr 9" non-locking converter, ~3200 stall. Ended up going with a lock-up on my new build. Trans was fine when it was pulled so it will be at the discretion of the new owner whether to have it cut open and flushed. Probably has 5-10k on it since I had it cut opened and freshened up by CPT many moons ago. I'd run it without issues if it were me but it's up to you. SOLD
Disc/drum combination valve. New in box. Comes with bleeder insert. SOLD
Gray console riser w/cup holders. Very good condition w/no stains, rips, etc. I removed the chrome trim on the cupholders because it reflects sunlight and will blind you going down the road and eventually wears off anyways. SOLD
Rubber floor mats. Same ones listed here which retail for $190 not including shipping. SOLD
![coilover brackets.jpg.jpeg coilover brackets.jpg.jpeg](https://turbobuick-data.community.forum/attachments/355/355108-bebc3c96382e31fa823f40e2770591c0.jpg?hash=vrw8ljguMf)
![SD2 chip.jpg.jpeg SD2 chip.jpg.jpeg](https://turbobuick-data.community.forum/attachments/354/354903-d1f750d531f09a124e7fd5d3a9049fb5.jpg?hash=0fdQ1THwmh)
![20240307_112043.jpg 20240307_112043.jpg](https://turbobuick-data.community.forum/attachments/354/354944-5ffdf6b29f61c190234ff79aeb438e3a.jpg?hash=X_32sp9hwZ)
![valve seal installer.jpg.jpeg valve seal installer.jpg.jpeg](https://turbobuick-data.community.forum/attachments/354/354907-cde7094f290b4d3b257028b77b80b188.jpg?hash=zecJTykLTT)
![valve cover gaskets.jpg.jpeg valve cover gaskets.jpg.jpeg](https://turbobuick-data.community.forum/attachments/354/354906-226b292f5b291e95a62bcefde5c2db9a.jpg?hash=ImspL1spHp)
