You don't really want more back pressure, less is better. One direct item with less back pressure is that the turbo will spool faster.
As for down pipe (DP) diameter, larger is better. The main reason is that as the gases exit the turbo they are spinning in a circle. With a smooth transition to the same diameter pipe, they continue to spin, and don't want to move down the pipe. Just spin around the inside of the DP.
Put a larger DP on and now there is an abrupt transition from the turbo to the DP. This causes turbulence which breaks up the spinning exhaust gases. This allows the exhaust gas to move down the pipe and out the tail pipes.
RemoveBeforeFlight
