last weekend I went to the dyno to get my car tunned and put down 321hp and 301 tq with a a/f curve at 13.9. We could not lower the a/f with out running really rich on the low end of WOT. So tonight I was tinkering around with the car and put in a new fuel pressure gauge and adjusted my fuel pressure about 2 psi. So originally, it was 40 with the line on the day of the dyno and tonight at 42 with line on and 47-48 with line off. Took the car for a spin after warming it up and saw 30psi
. Instantly I let off because something was not right and my chip is not burned for this ( turbo tweak chip 93 oct, 17-19 psi) but I did not see any knock on the scanmaster or hear any. I dont know what my o2 volts where because I was paying to much attention to the road and the boost gauge. I came to the end of the road and pulled a U-turn and stepped on it again, this time I saw 25 psi and about 1.2 degrees of knock. o2 volts the same as the first run, was not paying much attention to it. So my question is, did I do any damage to my engine while seeing 30 psi, knowing that my chip is not burned for that much boost?
Thanks for your time.
