301 N/A compatability with 301T parts question
Audiowizard
CARE FOR A SMOKE ANYONE?
Staff member
What are the differences between the N/A 301 block, crank, and heads verses the 301T block, crank, and heads? I am possibly purchasing the N/A parts as spares for my turbo T/A 301T. Thanks for your input.
Howdy,
The difference between the N/A 301 block and crank vs. the 301T. The 301T block particulary the main caps and deck area were made stronger. The crank is made stronger due to it being a rolled fillet design, whatever that means. I do know the normal stuff isn't suppose to be able to handle the load. As far as the heads if there are any differences it probably would be valve springs, other than that no problem swapping those.
Regards,
Turbo Ali X
I'd much rather boost, than Juice
