340L intank fuel pump
that looks about as safe as sharing a beer with a hooker whose upper lip is covered in cold sores...
Try it out, see how it works.
This is why I was asking;
Manufacturer: KEMSO in Japan
Part Number:
109
12
Condition:
New
The KEMSO 340 high pressure pump is capable of supporting applications of up to around 700-800bhp. This pump is also an ideal direct OEM replacement for stock OEM pumps that have gone faulty.
This KEMSO 340 pump is very similar to the popular Walbro 255 F20000169 (similar sized dimensions), with more flow. It's a high powered 340LPH fuel pump designed for use in many auto applications, whether it be daily drivers, fast road or if you're simply just looking to upgrade or replace your faulty fuel pump.
Kit Contents:
• 1 x Genuine KEMSO 340 Fuel Pump
(For gasoline vehicles, In-tank design, E85 Compatible)
• 2 x Gradient density Fuel strainers
(Two strainers included to cover all models)
• 1 x 8*280mm flex hose
• 1 x Wiring connector
• 2 x Crimp connectors
• 1 x Tank Seal
• 2 x Hose clamps
• 1 x Rubber base
• 2 x Zip-ties
Specifications:
Flow: 340 Liter per Hour, at 43psi, 13.5V
Operational Pressure: 43-90psi
Pump Body Diameter: 3.8cm
Overall Length: 12cm
Unrivalled KEMSO Quality Fuel Pumps
There is an increasing number of unbranded aftermarket parts coming onto the market. Do not compare KEMSO parts to other cheap aftermarket units on eBay, there is simply no comparison as many cheap part suppliers have little or no:
• Quality Control Program (ISO/TSO)
• Each pump individually tested
• Tested to flow 340 lph @ 43 PSI
• Lifetime Warranty
• Flow testing results
Why chance engine damage or reduced performance with an inferior fuel pump?
KEMSO are well known within all aspects of fuel delivery in Japan and was founded in 1998. You can be guaranteed that this is a 100% genuine KEMSO Pump that you're buying from a trusted seller.
