36# chip with stock injectors?
6SENSE
Im not planning on keeping it this way. I just dont have a stock injector chip sitting around. Just want to know would I be able to get the car running with my 36# chip (probably be my thumbwheel chip in stock [#2] position). Once I know that the engine starts up and runs, I'll get a stock injector chip.
Never mind, just got it running with the 36# chip. Hesitates when you get on the pedal in Drive or Reverse though. Also gave an O2 sensor code (lean). Both probably because of the chip, right?
yeah,it'll be lean.you could probably kick your fuel pressure up a few pounds to help out.i wouldn't drive it a whole lot that way tho:).
Thanks, I just swiped a stock injector thumb wheel chip from my brother earlier. I'll put it on tommorow.
The engine was running a bit hot while idling in park. Went up as high as 212. Thermostat is probably crap after sitting, and may not have even been a 160. I'll change it tommorow. I think H2O pump is new, but we'll see. My bet is thermostat.
TPS was .35 @ idle and 4.4 @ WOT. Boy we used to woop on some 400 c.i. Monte Carlos with this engine, wait till it finally gets some long awaited tuning.
Lots to play with :)
