Sep 28, 2010 #1 5 5 LTR KLR Member Joined Aug 8, 2002 Messages 134 In need of a 4.1 block only do to I have a cracked one now. Looking for one stamped this code: 25506484 Also need one .030 bore or under that...do to I have all rotating stuff. Please no junk, need real good one! I am in Wisconsin if that helps
Sep 28, 2010 #2 T ttaowner Well-Known Member Joined Jun 18, 2008 Messages 4,971 here you go http://www.turbobuick.com/forums/parts-sale/320585-4-1-block-na-v6-intake-kb-roller-rockers.html
Sep 28, 2010 #3 5 5 LTR KLR Member Joined Aug 8, 2002 Messages 134 ttaowner- I thank you for finding this BUT wrong stamp code. I was looking for one coded 25506424 Unless can someone tell me the difference between 25506484 and in that one which is coded 25514291 ???????
Sep 28, 2010 #4 T ttaowner Well-Known Member Joined Jun 18, 2008 Messages 4,971 according to the thread in the link the code that i have is better for some reason? if your interested let me know. TurboBuicks.com - Build a Budget 4.1 Motor!
Sep 28, 2010 #6 8 87GNSteve Just another pretty face.... Joined Jan 15, 2004 Messages 3,726 The 291 is better than the 484 because the 484 has water jackets that come too close to the each other and in turn crack toward them and then down the head bolt holes. Here is a discussion and a measurement between the two blocks: 4.1 casting numbers - Page 2 - TurboBuicks.com
Sep 29, 2010 #7 5 5 LTR KLR Member Joined Aug 8, 2002 Messages 134 I am still looking...WOULD like a stock one with code 291 as well. Virgin block please!!!!
Oct 3, 2010 #8 B black owned black pride Joined Jun 15, 2008 Messages 577 5 LTR KLR said: I am still looking...WOULD like a stock one with code 291 as well. Virgin block please!!!! Click to expand... i have one here in so ca.std bore with caps.whats you email i will get ya some pics.
Oct 3, 2010 #9 T Ttype6 Well-Known Member Joined Aug 17, 2004 Messages 3,898 5 LTR KLR said: I am still looking...WOULD like a stock one with code 291 as well. Virgin block please!!!! Click to expand... I have one here in Michigan.
