I have a 4.1 #4291 block std, its been cleaned and magged, it has a small crack in the front plate which should be covered by using 1/2 hardblock in it, also have a clean oil pan, new oil pick up, sealed powered pistons .030 installed on two dot rods, 214/224 flat tappet cam, and rollmaster double roller chain. i will throw in a .020/.020 crank for free if you want it. $700. for everything delivered if you re in new york/new jersey area. i also have 2 sets of stock iron heads -1 stock untouched and 1 set reconditioned. Matt 347 680 8642
