109 is a 3.79" bore
4.1 engine is 3.96" bore
What would the perfect way be to put 4.1 heads on a 3.79" bore?
Just say F-it!?? Is that the deal then?
Aren't there two different head gaskets for 3.8 vs/ 4.1?
Which should I use? The 4.1? Otherwise, the top of gasket would be exposed in the larger chamber, right? Gets burned up. Right?
We have a little cylinder wall above TDC to play with. Taper or bevel it just a little and use a 4.1 gasket??
Champion's web site kind of stinks. Mentions nothing about different heads, shaft mount vs. pedestal, stage I, stage II nothing about GN1R. Just a little generic story about the heads in general.
So, are the combustion chambers identical on all the GN1 heads?? Who knows??
Why does the outside of my box say 4.1 liter. It already states the heads are 14bolt and Stage II, then it states it is for 4.1. So what the heck does that mean? Nothing?
