4.1 kickdown throttle bracket different than 3.8?
79Poncho231
I've tried all three of my throttle kickdown brackets, and none of them fit. I have bent them every which way, but the (front-most forward) bolt hole on the bracket is wayyyy off from the intake hole, and even with one bracket hole drilled out, it's still not even close to the opening of the intake bolt hole.
Did the 4.1 have its very own bracket? My 2bbl bracket is #1262508. This intake came from a B-body 4-door sedan, according to the Different t-stat housing (Long neck). Was the bracket hole spacing slightly different from the G Body?
I need a 4.1 bracket ASAP...
