Ok' did some rebuilding on the car over the last year and had the engine out so when i put he car back together i noticed the the only way it will shift to 4th is if i let all the way off the throttle.  the car came with a converter so i installed it and this started.  it was fine with the stock d5 but this new converter wont  allow it to shit the way it used to nor does the converter lock.  there was no id numbers on the converter. all i know is its a 10 inch 2800 stall.  im wondering if the converter is a non lock up in a lock up trans.  if so would this cause my problem and is there any damage that can occur if the converter is the wrong style. had the pan off this weekend and checked the lock up solenoid and it working but still no lock up.  car has a fast system so the lock up is manual through a toggle switch.  thanks.
