4" inlet with 3" MAF pipe - will it clear the IAC?
jsta6
John 15:17
I have a TA66 with a 4" inlet bell. I am using a 3" maf pipe. I am using a 4" to 3" step-down hose for the turbo bell to maf pipe.
Will I be able to clear the stock location IAC? Or will I need the "angle boss"?
4 Inch Turbo Bell to 3 Inch MAF Pipe
I did this last night when I added a Turbonetics 60 Series Turbo with a 60-1 / P Trim Turbine onto my GNX
I also used a 4 inch to 3 inch bell adapter and when installed, the clamp (for the adapter to the 3 inch MAF pipe) was just touching the wires on the stock location IAC
Not hard enough to rub thru but close enough that I will probably put some friction material in between the clamp and the IAC wires
Good luck
Ray
Thanks.
Someone did mention that it would fit.
I went ahead and got the caspers relocation adapter anyway.
I put everything on today no problem.
