4 pin
jose
Whats up guys,i am swapping a monte ss trans into my TTA untill i am able to rebuild it correctly.It has a shift kit and a servo from CK.What do i do about the 4 pin connector on the side of the trans? and also, do i swap the TCC solenoid?
Thanks for any input.
You will need a 4 pin connector or else the one on your harness wont plug in. The 4th pin wont be doing anything with the Monte SS trans though, unless you want to drill and tap the VB for a pressure switch.
