Bowling Green is right around the corner so i will post this up to see if there is any interest. i am redoing my whole exhaust using aluminum after BG so this stuff will be forsale. i am running TA 4 bolt headers with the ac box. The dp has been coated with 2000 degree black coating from Jet Hot. the dp is made of mild steel with an o2 bung at the ac drier. it fits good but it has to go in with the header when putting it on. $350
the exhaust is mild steel painted black. it is 4" from the dp out to a single exiting in the stock location. it has 3 v-band clamps for easy on and off and two 4" hooker maxi-flow mufflers...one at the cat and the other before the axle. the exhaust fits good and goes over the axle with out touching anything. i have the H&R parts sway bar and it clears the piece that mounts on the axle tube. you will have to drill one hole in the trans crossmember and tap but everything else is pretty much bolt on......$650
the price is firm as i probably have this much in it, hours of welding(tig welded), and only around 150 miles. i can take it off in BG after the TAI race so this will save on shipping.i have 7 runs through exhaust all in the 10's..you can call me at 706 831 3641 thanks Bob
