You can use the rear disc system off a 4th gen Camaro or a Blazer. I've got an extra set of backing plates off a blazer if you're interested, but you'll need to do some cutting to the factory brake flange. Not hard to do but it takes a little work. There are also adaptors out there that use a simular caliper to the fronts and they either bolt on or weld on.
