T
Turbo 6 Justin
Guest
okay after spending a day and a half cleaning up the tranny fluid from everywhere, sanding and polishing the exhaust that is just fugly from all the fluid and fixing what I though was my tranny leak it still looks like it is leaking. it is a 400 and has all new lines the problem is the bottom line leaks. to be precise it looks like it is leaking between the fitting and the line itself (ie between the brass fitting and the steel line)
so for the questions just to make sure what size line should I be using? not that I could really screw this up
is there any way to seal it better, it isn't like thread tape would help since it is a flare fitting? I mean I have checked to make sure it is tight about 10 times. I will try to remove it tomorrow but I am very sure it is not crossthreaded. I suppose I could just bend up a new line but that might not do any good and will waste a lot of time.
Also it only leaks when I am giving it hell, I suppose as the line pressure comes up it basically overcomes the seal and 'sprays' fluid all over.
AHHHHHH this thing is killing me. It is kind of embarrising when your 11 sec car is smoking like an oil fire
thanks for any advise
