42lbs Injector's and Razors Alky ?
ikle
i did a search and nothing came up. How much boost can you run with 42lbs Injector's and Razors Alky ?
Thanks for your reply, Kyle.
Well, I have the same setup. My mechanic set me up at 22# every day and can go up to 25+ pounds if I go to the track. 22# and alky on 6'ish and I rarely ever see any knock.
I do have a TA-49 turbo and light supporting mods too, i.e. fresh fuel pump, hot wire, fresh valve springs, etc, etc if that matters.
Sent from my SAMSUNG-SM-G900A using Tapatalk
On twin m10s and 42s with a single pump,I ran 30psi sometimes less (depended on air quality)and went high 10s at 125mph with a ta49.
I run a te44 with 42 and alky with supporting mods. 27# of boost some knock once and while
Ok thanks for the info, I plan on running 20-25lbs, will a single nozzle be enough ?
I appreciate the help, Kyle.
