turboaddict2
- Apr 11, 2002
Sometimes the trans will lockup at 48mph in 4th gear. But then it will unlock again at 60 mph. Sometimes it will not lockup at all after it has shifted into 4th gear. The thing is I think its the chip. This locking and unlocking happens with a chip I got from eric marshall. When I put in my PTE chip it locks up consistently. I even talked to eric about the chip and he did all he can to fix the lockup. He said to check the VSS sensor or 4th gear switch. How does a chip not cause the trans to lockup? How do I check the 4th gear switch if its bad or not(never did this before)?
