50# injectors
FastRegalWE2
Wish I had another Buick!
I got a set and was going to put them in but I need to know if they will work with my Pit Bull chip, if not, what chip would I need to run them?
If it is a chip that is designed for 50# injectors, it will work fine. If the chip is setup for stock injectors, you will flood out everything. Most of the normal chip makers can do good 50# chips.
