5858 turbo results?
Started the day at 25psi. 11.3@117.8. Was running rich. Turned down fuel a touch, but compensated the rest with a little more boost. Car was responding nicely. Had a little bit of random kr, so pulled a little timing too. Has a 5.6 TT chip, and stock maf. At high rpm's was getting down to 10.1-10.2 Afr, but after the 2-3 shift came up to about 10.6, but dropped again towards end of track. SD chip probably in the future. Was launching at 22-23+ psi all day off of foot brake...
Big thank you to Steve(Beatav8)for always helping me with the tune. I know I'm not breaking any records here, but for a stock motor this thing is running pretty fast! He's helped big time with little gremlins the car had also. Still think there's room for improvement also. 122-123 mph? PTC 9.5" Converter is working great also! Approximately 7% slip up top with a 2800 stall
Time slip
That's a PTC 9.5" non-lock converter, correct? What is the stator blade count on it?
Thanks!
Pretty cool this turbo/ converter combo goes north of 20psi at the line with vacuum brakes to hold it
Here you go.
Ok, Thanks! Very nice combination... Do you by chance have a PL file you can share on that 10-sec. pass, or maybe just a screenshot showing the rpm graph? I have a very similar build going together for a car and we're looking at turbo options now.
Thanks!
I can try later from my laptop. Maybe Steve can chime in, and post it...
Something is wrong max mph is ~108?
Car.has a 28"tire and I forget the gear. 3.23 I think. Anyways that reported vehicle speed is way off due to stuff like that. The VS signal is pretty heavily filtered too.
That is because of the 9.5 N/L converter why the RPM is so flat.
Same thing happens to me when I let the car shift itself.
By "stock motor", do you mean heads, cam, valves, and rotating assembly? Or just stock bottom end?
Either way, that's hauling the groceries!
I changed the valve springs, had the intake manifold ported, and the throttle body ported. Heads have never been off, and stock cam.
