SignUp Now!218/212 roller cam,fmic,ported irons, pt6152e @28lbs 0f boost,4inch mass air flow,350 trans ptc 9.5nl, I hope thats good enough for youYou have better have one heck of a combo, or be super light weight to get that 6.67 in the 1/8.
What's you combo?
148 60 ftwhat sort of 60' times are you getting?
The reason i ask, i have trapped as high as 103mph in the 1/8th but only run 6.90s.
how much boost was you running and what was you leaving onthat's a nice combo. I didn't mean to sound like i did. It's just that i could only muster a 6.94 @ 99 mph my 60ft 1.52
very nice time.
yeah I was doing 7.20's with 1.75 60ft @100mph but the key is cutting that 60 down and when you grudging against a stroker mustang leaving on 175shot or better of spray I found that if you can leave on 12-14lbs of boost you come into to your power a lot quicker and if the track is right 9times out of ten that mustang dont stand a chanceIt was like 21-22 during the run, and leaving with 2.
how do you like that weber engine my next engine will be a strokerGood numbers. Last year with the 6152 turbo @ 22#, I ran a best of 6.81 @ 101.
what you guys think I left on 12lbs of boost with the 2step
What sort of 60' times are you getting?
The reason I ask, I have trapped as high as 103mph in the 1/8th but only run 6.90s.
What kind of boost can you spool up to at the line? Footbrake or transbrake?
I would think that you should be launching around 12-15# and running close to a 6.60 1/8 mile. You need to get the 60' down from 1.94 into the 1.45 second range.
My 60 was like 1.48 im leaving off the footbrake around about 10-12lbs of boostWhat kind of boost can you spool up to at the line? Footbrake or transbrake?
