O.k. I have a greddy boost controller, I have the M.T. E.t. street radials. I'm looking for some rims so I can get some slicks. How about air bags? Will they help at all? Thanks.
I don't think I would go with an air bag. Do you have subframe connectors? That should be the first thing, but judging by your current times you already have them. I would also go with tubular LCAs, panard bar, and a torque arm like Razor said. Shocks can also make a big difference but it's all about how you use what you have. With the stuff I mentioned and adjust right you could pick up a little but I don't think you're making enough power to come off the line too much faster than you already are. A 1.559 is very good especially if you have basically stock suspension.
My suspension is completely stock. I have had a couple of good 60' times, but I have had a lot more bad ones. I definitely need more track time. Maybe the inconsistecy is my fault. I got over aggressive at the line a few times, and just blew the tires off. Thanks for the info.
