6157bb
miz
Will the heat shield fit?When I try it hits the oil inlet line that came with turbo.The oil line is about 1/2 inch above turbo bracket.Just dont know if maybe I did something wrong.I was told it should fit when I bought it.
You did nothing wrong. You are correct, you either have to run a 90* fitting off of the supplied restrictor fitting, or else their oil filter relocation kit. If neither of those are an option, you will have to notch your heat shield like I did.
And for those who don't know what he's talking about, here's the problem.
Just one of those things that we either have to live with, or modify to work. Hot rodding is never easy and this is a perfect example.
HTH
Patrick
