john saleeby
- Aug 5, 2006
Need help finding cause of a whine when car is revved up.
Background: Installed new 6262 Dual Ball Bearing turbo purchased from Otto on my 87 GN. Spoolfool ported wastegate and took apart turbo to paint exhaust and center section (see sticky on "How to port and paint turbo"). The center section oil restrictor was removed for painting and then re-installed. Re-used the stock oil line that feeds center section of turbo and the stock oil drain line also.Took car for a test drive around block and hear a whine when accelerating and when decelerating (not under boost either time as we have not adjusted the boost yet).
Thought sound was from belt tension pulley so removed belt and pulley and whine still present.
Checked the following: AC compressor checked ok, alternator checked ok, checked crankshaft pulley for rubbing or sensor misplacement but that checked ok
Removed turbo compressor side and checked large orange O-ring, shaft, blades and bell for abnormal wear or play. Ckecked ok
Checked bolts that hold the exhaust side of the turbo in place and they were snug.
Anyone else have similar issue when installing this model turbo?
