SignUp Now!Altered Machine & Design
alteredmachine.com
anyone have something to say about these people(person)? with the go to guy retired I wondered if this could be the replacement goto .
Thanks 1KWIKSIX.Yes , they are both legitimate & highly qualified & recommended!
I thought that I read that, but I couldn't seem to find that statement again. If I have to mail my TB to Greg that's fine.If you read the info on his website, it states that he machines the throttle seal bore larger to accept a seal which is readily available , so not a direct drop in
You’d have to mail Greg your throttle body.
Might wanna try G Body Parts for a replacement OEM seal. Pretty sure I recall seeing them there![]()
As it turns out, Greg does not sell the throttle plates individually.If you read the info on his website, it states that he machines the throttle seal bore larger to accept a seal which is readily available , so not a direct drop in
Maybe it's not worth trying to replace the shaft seals and bushings. I bought my TB and Plenum as a package deal from a dude on TB about 7 years ago. He had purchased it from the Kirban, not sure if the seals and bushings were replaced. The main reason I wanted to replace them is they got powder coated because the person did not mask them off. I do believe they are 100% functional though, I am just being nit picking.The seals we have available to us now are a larger OD than factory. So it's too much press when installing. But check/measure your TB before you worry about that. Steve Monroe machined alot of these so yours could be fine. Otherwise the counterbore where the seals is located needs opened up. Don't think he makes bushings but I bet he could based on his credentials. Bushings need to be custom built per each used throttle body due to different wear present. I have done about 4 so far, all required slightly different size bushings to correct the issue. This is close tolerance work fellas. .0001" and you need to factor thermal heat expansion of aluminum body and steel shaft. I can tell you this type of repair makes one HELL of an improvement to your Turbo Buick!!
