87regal98formy
- Jul 24, 2007
Seller: Terry Depew
Price: $22,000 obo/ Trade for Turbo Buick
Miles: 56,473 ORIGINAL miles
Exterior:
New Paint less than a year old (Flawless, NO RUST, Straight body)
New Vinyl Top professionally installed
Bumpers rechromed
Interior:
All original interior
Bench Seat (only has one SMALL tear on top of drivers seat less than 1" long)
Crank Windows
Original Radio (doesnt work, but comes one and lights up)
Heat and AC has been removed and blocked off
Hurst Pistol Grip shifter w/ Line Lock button w/ removable aluminum cover
Auto Meter guages and Tach
Engine:
Balanced and built by Weber Performance
71 Buick 455 bored .30 over (462 cubic inches)
TA Performance Forged Pistons
ARP head bolts
ARP rod bolts
70 heads w/ Stainless Steel TA Stage 1 valves and springs
Pocket Ported heads
TA Performance SP1 aluminum intake
Kenne Bell 107/118 cam
NEW 850 Demon carb
MSD billet distributor
MSD 6AL
MSD coil
NEW Blueprinted oil pump and timing cover
Mickey Thompson Super Scavenger headers Ceramic Coated
NEW 100 Amp 1 wire altenator
Optima Red top battery
All New polygraphite bushings
Aluminum Radiator
Disc Brakes w/ NEW Booster and master cylinder
Kenne Bell valve covers
Transmission:
Built by PAE
TH400 "switch pitch" variable stall coverter 1,800 low stall and 4,000 high
Aluminum Deep trans pan
Rear differential:
12 bolt
Moser Axles
NEW bearing and seals
Eaton Posi unit w/ carbon fiber clutches
TA Performance Girdled cover
Southside Machine lower control arms w/ relocation brackets
Custom 3 1/2" Driveshaft
Exhaust:
TA performance 3" Mandrel Bent
Dynomax Ultra Flow Race mufflers
Seller: Terry Depew
Exterior:
Bumpers rechromed
Interior:
Crank Windows
Engine:
ARP head bolts
ARP rod bolts
Pocket Ported heads
NEW 850 Demon carb
MSD 6AL
MSD coil
Aluminum Radiator
Transmission:
Built by PAE
Rear differential:
12 bolt
Moser Axles
Exhaust:
