6776dbb a/r ID
Onalky87
There's nothing on the turbo hot or cold side that indicates whatcit is Only thing I see on the whole turbo is where it says precision. Any way to find out? I ask bc if I'm not misstaken the previous owner told me it was a .75 or something but on precisions sitecit only shows .63 and .85
Two places.
- Flat surface underneath the downpipe flange. (Meaning you would have to take the downpipe off to read the THB part number on the flat face of the turbine housing.) Either THB3-76 or THB5-76.
Example pic 1
- The A/R number should be located on the outside of the housing, just above the 3-bolt flange and on the inner most surface of the housing, closest to the bearing housing.
Example pic 2
Patrick
