have a 700r4 and put a b&m shift kit with a 2800 stall.does great drive it for a few mile and let it sit and it dont leak but sits over night and the fluid is all over the floor can anyone help please.....
4 new pan gaskets on it.. it blowing from the front 3 bolts in the front of the pan.. all bolts are tight but when it sits over night thats when it leaks...
it may be the pump bolts or pump oring above that area and it seems to be the gasket.or pan rail cracked,improper bolt torque or pan flange bent damaged
I really thank you for all your help.. just have to keep trying untill i find it..do you think it could be the breather tube on top of the tranny that might be pluged with dirt or something... I have a th350 tranny but not sure what i have to do to put that in the ta....
