70mm throttle body help
motomafia
hey i just installed a 70mm body on the car , cant get the throttle control to work properly ( the sping and arm that connects to the throttle cable ) any tips"?? tricks??? sounds real stupid but the throttle feels real spungy and isnt reacting properly ...thanks
You did install the 70MM upper plenum too right? Not just a stock upper plenum/ doghouse with the larger t-body?
The back bolt of the throttle cable / tv cable bracket needs to be shimmed up to be level... if not it will bind.
Email me at wanner@kc.rr.com when you post, some reason i dont get a message anymore when people post
BW
You made sure the back bolt of the bracket on the drivers side is spaced up and insnt moving right?
Elaborate what problem you are having
BW
well see the motor is in a 67 chevy 2 , the problem i think is with the actual throttle spring assm. . . the part directly on the new throttle body with the little level you connect the throttle cable up to...
