76 GTS or 88 3 bolt turbo and 160 lb injector
stage turbo t
Just like the heading says looking for 76 GTS or 88 3 bolt turbos (will consider anything in between but looking for 3 bolt) and 160 lb injectors.. Thanks DJ
The 76GTS does not come in a 3 bolt
3 bolt
norbs said:
Any reason for a 3 bolt?
Just want to play a little don't want to change over the down pipe and headers etc at this time. I know there are some of those old 88's with the TSE 3 bolt exhaust housing out there. Thanks DJ
I think the 3 bolt 88 won't fit on a 3 bolt buick header without some sort of adapter?
It will work, but the downpipe flange needs to be larger.
The dp flange for a 88 3 bolt has a wider bolt hole separation.
